Latest Firmware 2.0e - return of AirPrint and Sonos problems
Appreciate the difficulty here and i really do love my AP6 Pros when they are working properly, and well the size of the them compared next to the Aruba AP25s is laughable. They are about half the size and look so much nicer, which makes them easier to use at home. The speeds on a 1G uplink are about the same and the range is similar although the AP25s are a bit faster on a 2.5G uplink.
I am happy to try the new build and give it a go and report back, just need to time it right with the family etc. as I can’t break anything as I have exhausted all good will over the last few weeks :slight_smile:
User19 is in the same situation is me in terms of family and goodwill being almost exhausted.
That said I’m not currently seeing any issues at all which is good going.
Hoping a new firmware is on its way soon that will nail these problems once and for all.
Unfortunately, my workaround didn’t work today either. (Restart the APs at night via POE). Two Google Audio devices lose the connection again.
Hopefully you can fix this soon
Firmware 2.0g has been released. This should resolve discovery issues on flat networks, among other things. Thought I’d share the good news here.
Please let us know either way, thanks!
2.0g is the magic sauce which has fixed my AirPlay and AirPrint issues.
Thanks all - hopefully everyone else will have a similar experience to myself once they upgrade.
@oakserver @the Love to hear what you are seeing after deploying 2.0g
2.0g seems to be stable. No AirPrint or Sonos problems yet and my Meross Garage door openers seem to be working just fine as well. So far so good.
I’ll report back if I encounter any more issues. I’ve put my U6+ APs back in the cupboard for now :grin:
It looks like it fixed the Sonos issue. The Elgato Key Light is still having issues. And what’s really annoying is that I still have two Google Nest Audio devices that lose the connection after about 24 hours.
EDIT
Sonos issue is back… I can’t connect via the spotify app or Airplay (iOS and MacOS devices). But the Sonos app on the same iOS device can find the device…
Unfortunately, this update didn’t fixed my issues…
I can see many logs like this for the sonos device
Feb  6 08:20:05 OpenWrt daemon.info hostapd: 2b166Ixm9d: STA 54:2a:1b:d4:c2:32 IEEE 802.11: disassociated
Feb  6 08:20:05 OpenWrt daemon.notice hostapd: 2b166Ixm9d: AP-STA-DISCONNECTED 54:2a:1b:d4:c2:32
Feb  6 08:20:05 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=21 (2b166Ixm9d) alg=0 addr=0x24457c8 key_idx=0 set_tx=1 seq_len=0 key_len=0 key_flag=0x20
Feb  6 08:20:08 OpenWrt kern.warn kernel: [38221.219076] 2b166Ixm9d: STA 54:2a:1b:d4:c2:32, VLAN1, Type 0
Feb  6 08:20:08 OpenWrt daemon.info hostapd: 2b166Ixm9d: STA 54:2a:1b:d4:c2:32 IEEE 802.11: authenticated
Feb  6 08:20:08 OpenWrt daemon.info hostapd: 2b166Ixm9d: STA 54:2a:1b:d4:c2:32 IEEE 802.11: associated (aid 3)
Feb  6 08:20:08 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=21 (2b166Ixm9d) alg=0 addr=0x24457c8 key_idx=0 set_tx=1 seq_len=0 key_len=0 key_flag=0x20
Feb  6 08:20:08 OpenWrt daemon.info hostapd: 2b166Ixm9d: STA 54:2a:1b:d4:c2:32 WPA: sending 1/4 msg of 4-Way Handshake
Feb  6 08:20:08 OpenWrt daemon.info hostapd: 2b166Ixm9d: STA 54:2a:1b:d4:c2:32 WPA: received EAPOL-Key frame (2/4 Pairwise)
Feb  6 08:20:08 OpenWrt daemon.notice hostapd: Assigned VLAN ID 10 from wpa_psk_file to 54:2a:1b:d4:c2:32
Feb  6 08:20:08 OpenWrt kern.warn kernel: [38221.336178] STA update 54:2a:1b:d4:c2:32, VLAN10, Type 0
Feb  6 08:20:09 OpenWrt daemon.info hostapd: 2b166Ixm9d: STA 54:2a:1b:d4:c2:32 WPA: sending 3/4 msg of 4-Way Handshake
Feb  6 08:20:09 OpenWrt daemon.info hostapd: 2b166Ixm9d: STA 54:2a:1b:d4:c2:32 WPA: received EAPOL-Key frame (4/4 Pairwise)
Sometimes the Sonos Box is shown, sometimes not. Could this have something to do with these constant re-connects?
@Alta Team I would like an honest answer. I am a software developer myself and understand when you say that the issue is very complex and you can’t really say what the issue is at the moment. But I just have to think about using the Aruba APs again. So do you think you will be able to solve this in the next few weeks or not?
There also seem to be simple connection problems. See some comments here in the forum, my own connectivity issues with the Google devices and apparently the Sonos box seems to be constantly reconnecting.
Disappointing to hear that you’re still having problems.
Luckily mine is behaving well but I don’t have the complexity of your network. I have one IOT vlan 10.
My Sonos are on the main network vlan 1 along with all the devices that control Sonos. Luckily I have no google devices so that’s not affecting me.
The Sonos device is on the same vlan as my main devices.
VLAN 1 => switches and access points
VLAN 10 => private devices and sonos.
VLAN 40 => some iot devices (bulps… and 4 google devices. 2 nest audios, 2 nest minis, Canon printer)
I never had AirPrint issues, but my printer is off most of the time. just switch it on when I need to print something. Maybe thats the reason why I don’t have issues with AirPrint.
Beside the connection loss I don’t have any issues with the Google Devices.
They are always accessible via the Google Home App… I can stream from the spotify app, they can control the bulbs… But after ~24 hours they lose the connection. But just the 2 Audios. The minis are working perfect…
So my main issue is the sonos box and those disconnects with the two Google Audios. And especially the disconnects are really annoying.
The Elgato keylight is also on my main vlan since last night.
Now it is definitely available more often, but not always. But I don’t care at the moment. I use it just for video calls and can switch it on and off quite easily using a curl command. I’m fine with that for now.
Maybe I should try to use just one main VLAN with access points… switches… all my main devices. @alta team Do you think this will help?
@the if you do try that and it seems to work better it could be another variable we can keep in mind…
I can do that. But I don’t know if I can do it before the weekend.
At the moment I also want to check the changes I made yesterday.
I have done a factory reset of the APs and also reactivated the 5GHz for the IoT SSID.
This was also the case with my Aruba APs. I just thought that I didn’t actually need it because the Google devices should also work well with 2.4 GHz.
Maybe this will fix the connections issues. But I don’t know. Lets see what will happen until tomorrow.
@the Technically flattening the network would likely work around what you’re seeing in your multi-VLAN configuration. That said, we do have a command we can try if you’d like to try a potential fix that will work in your existing configuration. One of us would need to be invited to your site temporarily as an admin (pw access isn’t needed) to input the commands and reboot the AP(s). Please reach out if that is of interest.
@Alta-MikeD Yes, I’m definitely interested. Jeff Hansen is still administrator of my site.
Google Nest Audio Issue news:
Since ~30 hours they are connected to 5Ghz of the IoT VLAN 40.
One device is connected to an AP6. This device has just lost the connection a few minutes ago.
I can see a lot of disassociated and associated events in the AP6 log. Somehow it can’t reconnect again. (restart of the google device helped)
Is this log ok? Because its. something about VLAN1. The device is/should connected to VLAN40
Feb  7 13:00:04 OpenWrt kern.warn kernel: [141064.247828] 2x5pDz6hTW: STA MAC_ADDRESS, VLAN1, Type 0
The other google device is connected to an AP6 pro and is still connected.
Btw. the 2 google mini devices are also connected to the ap6 pro. maybe its just an issue with the ap6.
@Alta-Jeff has enabled the experimental feature yesterday.
Since then, I was always able to access the Sonos system via AirPlay and Spotify Connect. Therefore I’m optimistic that the Sonos problem has also been resolved for me. :clap:
theoretically there is only one issue left: Wifi disconnects of the Google Audio device that is connected to the AP6. Or could the experimental feature have solved this problem too? At least I haven’t had any crashes today. But sometimes it just takes time @Alta-Jeff
@the If you can let me know shortly after it disconnects (via DM), I can grab the logs and try to understand what’s initiating the disconnect.
-Jeff
