Switch - Release Notes
Thanks for all of your feedback helping improve the Alta products!
2.5d
Released on 11/09/2026
  • S24-POE/S48-APOE/S12: Add support for L3 routing
  • S24-POE/S48-APOE/S12: Add support for L3 ACL rules
  • S24-POE/S48-APOE/S12: Add support for DHCP relay and server
  • Add support for mapping wired MACs to a VLAN, network-wide
  • Add support for SNMP RFC-4188 Bridge MIBs
2.5c
Released on 11/03/2026
  • Mitigate CVE-2026-98432
2.5b
Released on 10/23/2026
  • Remove eMudhra and Sectigo/Comodo AAA root certificates
  • Address several Linux potential skb vulnerabilites, including ZDI-CAN-33367
2.5a
Released on 10/22/2026
  • Revert to original config after fallback-upon-failure is no longer necessary
2.3z
Released on 09/24/2026
  • Improve IGMP snooping efficiency on larger sites
2.3y
Released on 09/16/2026
  • S48-APOE: Resolve rare issues with packet loss on 2.5G ports, introduced in 2.3x
2.3x
Released on 09/09/2026
  • Improve IGMP Snooping reliability
  • Add ICMP monitoring timeout option
2.3w
Released on 08/27/2026
  • Add support for ICMP monitoring, per-port
2.3v
Released on 08/20/2026
  • Improve CPU consumption on larger sites
  • S12/S48-APOE: Improve fan handling
2.3u
Released on 07/21/2026
  • Add support for Switch Port Schedules.
  • Add support for Custom Update Windows.
2.3t
Released on 07/15/2026
  • S12: Add support for temperature reporting
  • Save historical temperature statistics
  • Improve controller connection reliability
  • Improve resource utilization for on-device statistics
  • Improve switch connectivity when using non-default management VLAN
2.3s
Released on 04/20/2026
  • Add support for publishing user-configured port names in SNMP.
2.3r
Released on 04/01/2026
  • Add support for QoS prioritization, including common profiles and manual overrides.
2.3q
Released on 03/10/2026
  • Resolve issue with STP blocked ports not being reported.
  • Improve system stability.
2.3p
Released on 02/04/2026
  • Add support for reading SFP port DDM info (RX power, temperature, etc.), optionally enabled under Settings->System->Advanced.
  • Add support for reporting firmware updates to audit log.
  • Add support for reporting storage usage.
  • Improve reliability for system storage.
  • Resolve DHCPv6 issues when IGMP snooping is enabled.
  • Reduce DNS traffic used for connectivity checks.
  • Resolve DNS resolution issues introduced in 2.3o.
2.3o
Released on 01/29/2026
  • Add support for reading SFP port DDM info (RX power, temperature, etc.).
2.3n
Released on 12/11/2025
  • Add support for learning Device IP addresses using ARP requests in addition to responses.
  • Resolve issue with DHCP guard when gateway MAC changes.
2.3m
Released on 12/03/2025
  • Improve handling of potentially incorrect network settings.
2.3k
Released on 11/11/2025
  • Improve overall system stability.
  • Improve IGMP snooping support on S48-APOE/S12.
2.3j
Released on 10/24/2025
  • Resolve issues with initial configuration, introduced in 2.3i.
2.3i
Released on 10/23/2025
  • S24-POE/S48-APOE/S12: Resolve IGMP snooping issues.
  • Improve IGMPv3 join parsing.
  • Improve CPU responsiveness on larger sites.
2.3g
Released on 09/15/2025
  • Resolve configuration issues with extremely large configurations.
  • Improve compatibility with legacy DHCP servers.
2.3f
Released on 09/04/2025
  • Resolve IGMP snooping issues on S8-POE, S16-POE, and S48-APOE.
  • Resolve issues with DHCP servers that always respond to broadcast IP.
2.3e
Released on 08/25/2025
  • Improve system memory utilization.
  • Resolve potential system lock-up on S24-POE (would occur very intermittently on boot-up).
2.3d
Released on 08/20/2025
  • Improve CPU utilization, particularly in networks with heavy broadcast/multicast traffic.
  • Resolve issues with missed multicast traffic across LACP links.
2.3c
Released on 08/07/2025
  • Add support for persistent logging.
  • Add support for real-time logs in management platform.
  • Resolve issues with STP blocked port reporting.
2.3b
Released on 07/01/2025
  • Add support for S48-APOE and S12.
  • Add support for HTTP time-sync if NTP is unavailable.
  • S8-POE/S16-POE: Improve IGMP Snooping.
  • Improve STP BPDU handling.
  • Improve management CPU latency.
  • S24: Resolve issues with manual 1Gbps setting on SFP ports.
  • 802.1X: Resolve issues when a device links back up.
  • S24: Resolve stability issues introduced in 2.3a.
2.3a
Released on 06/27/2025 Pulled
2.1u
Released on 03/20/2025
  • Improve IGMP snooping support.
2.1t
Released on 02/21/2025
  • Improve uplink detection.
2.1s
Released on 02/13/2025
  • Add support for configuring flow control.
  • S8/S16: Resolve incorrectly reported ports on LACP links.
  • Improve IGMP snooping stability.
2.1r
Released on 01/08/2025
  • Improve reporting for combined ports (LAG/LACP).
  • Improve IGMP snooping reliability.
2.1q
Released on 01/02/2025
  • Enable support for LACP on combined ports.
2.1p
Released on 12/17/2024
  • Improve memory utilization.
  • Resolve issues with IGMP snooping leave messages.
  • Resolve issues with IPv6 multicast groups when more than a few VLANs are configured.
2.1o
Released on 11/12/2024
  • Improve DHCP guard when static IP is configured.
  • Improve IGMP leave with multiple subscribed devices.
2.1n
Released on 10/30/2024
  • Add support for historical per-port statistics.
2.1m
Released on 10/17/2024
  • Resolve issues with IGMP snooping.
2.1l
Released on 10/11/2024
  • Add support for DHCP guarding.*
  • Improve LLDP reporting for more accurate topology map.
  • Add SFP module reporting.
*Note: The DHCP guarding option can be enabled in Settings->System->Advanced.
2.1k
Released on 10/01/2024
  • Improve responsiveness immediately after configuration change.
2.1j
Released on 09/16/2024
  • Resolve issues with IGMP Snooping on S8 and S16.
  • Resolve issues with expiring IGMP Snooping entries for dynamic IPv6 addresses.
  • Resolve issue of re-enabling link-lights on S8 (no longer requires power cycle).
2.1i
Released on 07/19/2024
  • Add support for controllers behind reverse proxy.
2.1h
Released on 07/12/2024
  • Improve IGMP Snooping in cases where VLAN1 did not have it enabled, but other VLANs did.
  • Improve time synchronization for cases where NTP is blocked or marginal.
  • Improve support for local controller.
  • Improve discovery of devices to local controllers.
2.1g
Released on 06/24/2024
  • Resolve issue in sending stats from switches with heavy usage.
  • Resolve several issues with IGMP Snooping.
  • Resolve several issues with SNMP reporting: CPU port stats and MTU reporting.
  • Enable jumbo multicast frame support.
2.1f
Released on 05/20/2024
  • Add temperature and fan reporting for SNMP.
  • Resolve incorrect IP reporting on S8-POE devices.
  • Resolve incorrect STP blocking reporting.
2.1e
Released on 04/17/2024
  • Add support for SNMP monitoring.
  • Resolve issues with IP address tracking on S8-POE.
2.1d
Released on 03/22/2024
  • Add support for wired device IP address tracking.
  • Resolve intermittent issue with POE and temperature not reporting.
2.1c
  • Add support for setting desired loop detection protocol.
  • Add support for setting STP priority per-switch.
  • Add support for viewing STP blocking state in management platform.
2.1b
  • Resolve issues with local controller.
2.1a
  • Add support for MSTP/RSTP/STP.
  • Add support for local controllers.
  • Resolve issues with LLDP on S24-POE.
  • Improve stability when IGMP snooping is enabled.
1.2m
  • Improve stability under network loop conditions.
  • Improve management connection stability in networks with many VLANs.
  • S24: Resolve issues with rebooting via management platform.
  • Resolve issues related to IGMP Snooping.
1.2k
  • Add support for 802.1X authentication.
  • Resolve issue setting static IP address.
1.2j
  • Add IGMP and MLD Snooping Support*.
  • Fix Static IP Address assignment.
  • Various stability improvements.
*Note: IGMP Snooping is not recommended to be enabled by default. Only for networks with IPTV, or other special environments. It must be configured on individual VLANs. We also added an IGMP/MLD Querier, and support for Leave messages to ensure group correctness.
1.2i
  • Add support for LLDP-MED Voice VLAN.
  • Add support for disabling link light LEDs (not including POE LED).
1.2h
  • Add LLDP support.
  • S24: Enable SFP+ LEDs.
1.2g
  • Add support for remote syslog host.
  • Use configured name as system hostname.
1.2.f
  • Improve network fallback functionality.
1.2e
  • Add support for displaying POE status.
  • Add support for power cycling POE ports.
  • Add support for displaying switch temperature.
Switch | Release Notes?
Switch Firmware 2.1a Released!
Broadcast Storm & Crashed Switches
STP / RSTP support?
LAG 802.3ad feature
Switch Firmware 2.3k Released!
[PULLED] Switch Firmware 2.3a Released!
Switch Firmware 2.3o Released and Pulled
Switch Firmware 2.3p Released
Switch Firmware 2.3m Released!
Switch Firmware 2.3n Released!
Switch Firmware 2.3c Released!
Switch Firmware 2.3d Released!
AP Firmware 2.2p Release Notes?
Switch Firmware 2.3f Released!
Switch Firmware 2.3g Released!
Switch Firmware 2.3i Released!
Switch Firmware 2.3j Released!
Switch Firmware 2.3s Released
Switch Firmware 2.3q Released
Switch Firmware 2.3t Released
Switch Firmware 2.3u Released
Switch Firmware 1.2m Released!
Switch Firmware 2.3w Released!
Switch Firmware 2.3x Released!
Switch Firmware 2.3y Released!
Switch Firmware 2.3z Released!
Switch Firmware 2.5a Released!
Switch Firmware 2.5b Released!
Switch Firmware 2.5c Released!
Switch Firmware 2.5d Released!
Switch Firmware 2.3v Released
IGMP Support for managing multicast traffic
Switch Firmware 2.3b Released!
Switch firmware 1.2k released!
Switch Firmware 2.1b Released!
Switch Firmware 2.1c Released!
**Some awesome new firmware updates out today!
July 15 - Big updates
Switch Firmware 2.1m Released!
Switch Firmware 2.3r Released
Switch Firmware 2.1n Released!
Switch Firmware 2.1o Released!
Switch Firmware 2.1u Released!
Switch Firmware 2.1p Released!
Switch Firmware 2.1q Released!
Switch Firmware 2.1r Released!
LAG/Aggregate - Alta Switching
LACP support on Switches
Link aggregation...am I doing something wrong?
Switch Firmware 2.1s Released!
Bug in LACP reporting in Devices list
Control display bug for LAG connections?
Switch Firmware 2.1t Released!
This update enhances firmware stability and refines IGMP snooping performance for more consistent network operation.
Join the discussion and share feedback HERE.
This release refines how the system processes unexpected configuration scenarios.
This release improves client-tracking reliability and addresses conditions that could cause unexpected behavior.
This release enhances monitoring and audit reporting, improves overall system reliability, and resolves several network-related issues.
NOTE: This release has been pulled temporarily, as we are seeing higher than usual disconnections after upgrade.
This is a hotfix release for 2.3o which also brings enhancements to monitoring and audit reporting, improves overall system reliability, and resolves several network-related issues.
This firmware release includes improvements to overall system stability and reliability, along with enhancements to network state monitoring and reporting.
This release delivers enhanced traffic management with new QoS prioritization support, featuring standard profiles and flexible manual overrides for finer control.
To use QoS prioritization on Alta Switches, look towards the very end of each Port or Port Colors’ options
This release focuses on improving visibility and integration with external monitoring systems.
