AP Firmware 2.2h Released!
Our latest firmware release for APs is here, delivering improved functionality and critical fixes to enhance your experience:
  • Add support for optional PMF setting.
  • Report LLDP uplink to back-end, to identify last known connected port.
  • Improve overall system stability.
  • Improve fast roaming reliability.
  • Improve auto-channel planning reliability.
  • Improve mesh uplink selection.
  • Improve reliability of RADIUS accounting stats transmission.
at a quick glance, seems to work as expected, and probably solving the issues discussed in this thread
Overall my wireless stability has been improved for me, been running 2.2h since it was released. With 2.2f, I did experience a symptom that was unrelated to the main problem in this thread: Entire Network Will Go Down When Desktop Is Connected, as I was seeing repeated dropped connections for some of my IoT devices. To make that more stable, I had to set my Air-Time efficiency to 1000kbps. With 2.2h, I noticed that I was able to revert Air-Time efficiency back to defaults and those IoT devices no longer disconnect. So, I’m liking 2.2h so far! It seems to have fixed the issue that I was seeing in 2.2f.
Thank you Alta team!
