Since the last update my wifi upload speeds have been horrible. I’ve tried everything I can think of - cycled through all the acceleration options, changed the 5GHz band to 160MHz, and I cannot figure it out.
I have a route 10 and a AP6 connected to L2. The internet is 2G/1G which I can get full speed on my wired network hanging off the 2 SFP ports. On the AP6 I am getting 700Gbps down and 150 up with no acceleration (acceleration doesn’t work with my network and I get 150 trying all the options up). I’m sure it would be better when I can get my hands on an AP7-pro and connect it to my 10G network, but I can’t find any.
In researching I found some info on port forwards causing issues and another article said that using LACP on the 10G ports had hashing problems which would cause wifi degradation. I don’t believe everything I read so can someone shed a light on this?
Please, check my topic on this forum. It can be latest firmware issue for your setup too. Also one note, 700 Mbps download on AP6 is quite normal as uplink AP port is 1 Gbps, the upload 150 Mbps is an issue.
