Switch Firmware 2.3w Released!
  • Add support for ICMP monitoring, per-port
I must have a case of the Fridays… I cannot figure out what this feature is. Can someone give me a quick overview?
Ping watchdog is probably the better known terminology.
Specify an IP that’s fixed (static or by DHCP reservation) and if that host is unreachable, the port is cycled
Thank you. I assume this isn’t on local controller yet, which is probably why I couldn’t find anything related to it on my system.
That’s correct, it will need a controller update. Likely next week.
This feature is amazing.
