Switch Firmware 2.3r Released
This release delivers enhanced traffic management with new QoS prioritization support, featuring standard profiles and flexible manual overrides for finer control.
  • Add support for QoS prioritization, including common profiles and manual overrides.
To use QoS prioritization on Alta Switches, look towards the very end of each Port or Port Colors’ options
I did a speedtest run (via Android client connected to AP downstream of S8 switch) and noted that there may be some mutation with CAKE possibly being introduced here. Without CAKE (or IDS/IPS) I see 930/930 download/upload, and with CAKE enabled at 875/875 I get speedtests at 350/830. The 350 was not expected. It has been running steady on levels much higher than that for some time before. That’s using Black color and Default QoS.
Might be best to refrain from Firmware releases on 1st of April in future years!!!
