This update enhances firmware stability and refines IGMP snooping performance for more consistent network operation.
Improve overall system stability.
Improve IGMP snooping support on S48-APOE/S12.
Usually you just have to refresh the page if it’s not already showing as available. Same for mobile and web. On mobile you just pull down to force a refresh. Browsers you’d just use the refresh button, or your preferred refresh shortcut.
Sorry guys, I simply replied without checking. I can confirm it does not appear to actually be pushed. I’ve escalated this internally; we’ll get this sorted.
Thanks for the reports and sorry that I didn’t check when I made my earlier reply.
@anon77415413@panthergm this has now been fixed, and I did double check locally before posting just in case. You should be good to go. Thanks again for reporting this!
Obviously please don’t hesitate to reach out if not, or if you have any other feedback. Thanks!
