Route10 Firmware 1.4u Released!
This release enhances WAN visibility and routing capabilities, improves VPN interoperability, and expands advanced dynamic routing support.
  • WAN Status:
    • Add support for Speed Test.
    • Add support for Site Location.
  • Improve L2TP server compatibility with Windows clients.
  • Dynamic Routing: Add support for IS-IS.
I updated my route 10 from 1.4t to 1.4u and the internet has been down since. I had to power on reset and reset the modem just to get connected with no internet. The cloud controller was then able to contact the route 10 but still no internet connectivity for my devices. I was able to run the new speed test from the controller. When I hit setup on the route 10 it was very glitchy. Seems like an issue routing the LAN/VLANs to the WAN.
Do you have IPv6 & IPv4?
both were enabled.
If Ipv4 still broken:
on the route10, can you please run and share output of:
ip neigh show
ip route get [WAN IPV4 address]
@Alta-MikeD looks like the same issue we have beenm discussing via PM if you can share the script etc with @bigcntry194
just got it back up. I deleted my local DNS routing and did another power on reset.
What commands did you run?
None yet. all was done from the cloud controller.
How did you do this from the cloud controller?
Trying to find the steps that resolve the issue so we can get a proper fix :slight_smile:
settings>networks
click on each network and in the pop out deleted my local dns ip address from the dns servers box and saved. had to again do a power on reset before connectivity was restored.
I am also dead in the water, with everything disconnected. Using the Cloud Controller so unable to connect to any Alta devices.. Is there a formal statement on how we recover the network ? I dont want to make things worse by inadvertently erasing the configuration. Also wondering about the Alta Release process as this is not the first time an update has caused issues.
  • I have now performed the power on reset on Route10. devices have reconnected to the cloud controller BUT the route10 cant make up its mind if it wants a firmware update or not (it seams to have settled wanting to reload 1.t) . Also its reporting that requires setting up. So still allocated to my site.
  • Its taken two Power on resets on the Route10 to recover the network. Its running on 1.u and wanting to revert to 1.t. I hold off on that for the minute. Route 10 still wants to be “Set up” but appears to have the correct config.
As I have said above the Alta software Release procedure need really looking at from a Quality Standard point of view. This should just not happen in these enlightened days. For me it was no heating, no lights, car has not charged and more. I feel for those who have the route10 in production networks as it appears this require physical presence to effect a recovery, well it was in my case
Unfortunately the same here.
Mine is also dead in the water. Need to go over recovery procedures.
It is at times like this that one really would like to have central logging so that one could go over why/when issues occure.
I don’t even get DHCP address from my R10
Do you have IPv6 @ebuckland81 @e697da861624e2c9c75d @don.mclean ?
Is your WAN PPPoe or DHCP?
Can you access IPv6 enabled websites?
Can you access https://manage.alta.inc/?
This disconnected the internet for me.
Good to see the Dashboard getting some love.
Things to add: client connected over time as a barchart…
rework the UI - it feels like its for kids and to much whitespace everywhere…
I belive you can do better! I love the hardware but the GUI needs to more modern and up-to-date…
WAN port conf:
IPv4 DHCP
Via Manage I could see ‘disconnected’ on all things.
After reset it is now running 1.3z and the “Set up” icon does not go away.
You can reach me on Discord also >> SobriuS
Is there any way to manually update to previous release before this?
Updated:
SETUP icon has disappeared finally. But I am having issues getting my S8-POE & AP6-PRO to be connected
I could reach the alta page and logon without issues.
I do not run ipv6 on the wan. I do run it on my local networks as i use “Matter” in home automation.
My wan is DHCP via SFP
IPv4 only in my case. DHCP via WAN SFP. Neither of power off and on, reset while on or Power-on-Reset seems to provide connectivity yet. All seems fine in the UI, LEDs blinking like I suppose they should, and Route10 responds to LED-settings etc., but no connectivity to WiFi or Ethernet yet. Next step may be to wipe out the entire network and PoR the hell out of it. :grimacing: Though, not entirely sure if it actually PoR entirely as the firmware should have been downgraded a few steps in that process…
Edit: So, not up and running yet, but I did note a few things. I could connect to the Route10 via Cloud UI ssh-terminal, the speedtest worked → WAN is functional. I got a bunch of APIPA warnings on fallback IPs. Some devices carried their proper IPs but were not accessible from their respective web based or app based UIs. Now, if I managed to cat the correct file, the very interesting issue was that the dnsmasq config showed no DHCP-ranges for anything else than the native VLAN, So, everything else than my network devices (native) VLAN is effectively locked out as I try to access them from SSIDs or via Ethernet via S8-switches set up for specific VLANs only?! Anything familiar here?
I found I had to reboot several times like lots, and eventually the potential race condition might be solved…
Did you want to try ssh and try the following, also sent you a PM @ebuckland81 based on what Alta support shared with me.
Also asked for these:
ip neigh show
potentially something with the ipv4 routing table causing the issue, but still not sure why.
