RADIUS-assigned VLANs
Hi,
Could someone please confirm whether the new Alta Labs APs properly support RADIUS-assigned VLANs when using WPA2-Enterprise on an SSID?
I presume it would with no problems, especially as Ubiquiti UniFi and like APs all support this. However, I do not see any tickbox or option in the Alta Labs cloud console to explicitly enable this feature, which there is on UniFi. Therefore, I would assume that the APs have this enabled by default, but I wanted to check if anyone else has tested this before I purchase the APs for myself.
Thanks
Hi @itservicesx thanks for posting! Yes, we support RADIUS assigned VLANS automatically. No extra configuration is needed.
Brilliant, glad to hear. How about RADIUS controlled MPA for multi-passwords on a single SSID? I believe TP-Link Omada supports this, where an admin can configure the AP to either host the passwords locally, or use a RADIUS server instead.
Does the Alta Labs cloud management platform support this?
@itservicesx Yes, you should just be able to point the AP to the RADIUS server, and the RADIUS server can handle the authentication directly with the station.
are there specific attributes that should be sent on access-accept?
I tried the generic attributes that work with most vendors, but always get stuck onto the default vlan:
radiusd:1053:1690323127.353635:Tue Jul 25 15:12:07 2023: Tue Jul 25 15:12:07 2023 : Debug: (16) Sent Access-Accept Id 40 from 172.16.16.11:1812 to 172.16.91.104:59217 length 0
radiusd:1053:1690323127.353734:Tue Jul 25 15:12:07 2023: Tue Jul 25 15:12:07 2023 : Debug: (16)   User-Name := "host/hostname.local.domain"
radiusd:1053:1690323127.353750:Tue Jul 25 15:12:07 2023: Tue Jul 25 15:12:07 2023 : Debug: (16)   Tunnel-Private-Group-Id += "201"
radiusd:1053:1690323127.353765:Tue Jul 25 15:12:07 2023: Tue Jul 25 15:12:07 2023 : Debug: (16)   Tunnel-Type += VLAN
radiusd:1053:1690323127.353784:Tue Jul 25 15:12:07 2023: Tue Jul 25 15:12:07 2023 : Debug: (16)   Tunnel-Medium-Type += IEEE-802
@aglabs If you can grab /var/log/messages right after the client connected (via ssh/scp), perhaps we can understand why it’s not assigning the desired VLAN in your case.
First things first, huge fan of how easy it was to figure out how to ssh to the AP and setup SSH keys.
messages log from connection attempt:
Jul 26 02:14:41 OpenWrt kern.warn kernel: [  343.282883] 5eBPVRYKrl: STA f0:9e:4a:b2:07:7d, VLAN4, Type 0
Jul 26 02:14:41 OpenWrt daemon.info hostapd: 5eBPVRYKrl: STA f0:9e:4a:b2:07:7d RADIUS: VLAN ID 4
Jul 26 02:14:41 OpenWrt daemon.info hostapd: 5eBPVRYKrl: STA f0:9e:4a:b2:07:7d IEEE 802.11: authenticated
Jul 26 02:14:41 OpenWrt daemon.info hostapd: 5eBPVRYKrl: STA f0:9e:4a:b2:07:7d IEEE 802.11: associated (aid 1)
Jul 26 02:14:41 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=15 (5eBPVRYKrl) alg=0 addr=0x124a438 key_idx=0 set_tx=1 seq_len=0 key_len=0 key_flag=0x20
Jul 26 02:14:41 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=15 (5eBPVRYKrl) alg=8 addr=0x595566 key_idx=1 set_tx=1 seq_len=0 key_len=32 key_flag=0x1a
Jul 26 02:14:41 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=15 (5eBPVRYKrl) alg=11 addr=0x595566 key_idx=4 set_tx=1 seq_len=0 key_len=32 key_flag=0x1a
Jul 26 02:14:41 OpenWrt daemon.err hostapd: no such r0 nor r1 for: f0:9e:4a:b2:07:7d
Jul 26 02:14:41 OpenWrt daemon.notice hostapd: 5eBPVRYKrl: CTRL-EVENT-EAP-STARTED f0:9e:4a:b2:07:7d
Jul 26 02:14:41 OpenWrt daemon.notice hostapd: 5eBPVRYKrl: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=1
Jul 26 02:14:44 OpenWrt daemon.notice hostapd: RADIUS: Retry attempts :2 Maximum retry attempts :10
Jul 26 02:14:44 OpenWrt daemon.info hostapd: 5eBPVRYKrl: STA f0:9e:4a:b2:07:7d RADIUS: VLAN ID 4
Jul 26 02:14:44 OpenWrt daemon.err hostapd: no such r0 nor r1 for: f0:9e:4a:b2:07:7d
Jul 26 02:14:44 OpenWrt daemon.notice hostapd: 5eBPVRYKrl: CTRL-EVENT-EAP-SUCCESS2 f0:9e:4a:b2:07:7d
Jul 26 02:14:44 OpenWrt daemon.info hostapd: 5eBPVRYKrl: STA f0:9e:4a:b2:07:7d WPA: sending 1/4 msg of 4-Way Handshake
Jul 26 02:14:44 OpenWrt daemon.info hostapd: 5eBPVRYKrl: STA f0:9e:4a:b2:07:7d WPA: received EAPOL-Key frame (2/4 Pairwise)
Jul 26 02:14:44 OpenWrt daemon.info hostapd: 5eBPVRYKrl: STA f0:9e:4a:b2:07:7d WPA: sending 3/4 msg of 4-Way Handshake
Jul 26 02:14:44 OpenWrt daemon.info hostapd: 5eBPVRYKrl: STA f0:9e:4a:b2:07:7d WPA: received EAPOL-Key frame (4/4 Pairwise)
Jul 26 02:14:44 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=15 (5eBPVRYKrl) alg=8 addr=0x124a438 key_idx=0 set_tx=1 seq_len=0 key_len=32 key_flag=0x2c
Jul 26 02:14:44 OpenWrt daemon.info hostapd: 5eBPVRYKrl: STA f0:9e:4a:b2:07:7d WPA: pairwise key handshake completed (RSN)
Jul 26 02:14:44 OpenWrt daemon.notice hostapd: 5eBPVRYKrl: EAPOL-4WAY-HS-COMPLETED f0:9e:4a:b2:07:7d
Jul 26 02:14:44 OpenWrt daemon.notice hostapd: 5eBPVRYKrl: AP-STA-CONNECTED f0:9e:4a:b2:07:7d
Jul 26 02:14:44 OpenWrt daemon.info hostapd: 5eBPVRYKrl: STA f0:9e:4a:b2:07:7d RADIUS: starting accounting session 81EC9125053A08BA
Jul 26 02:14:44 OpenWrt daemon.info hostapd: 5eBPVRYKrl: STA f0:9e:4a:b2:07:7d IEEE 802.1X: authenticated - EAP type: 13 (TLS)
accompanying lab radius server logs on the access-accept packet (its a modified freeradius build):
radiusd:14899:1690337684.627970:Tue Jul 25 19:14:44 2023: Tue Jul 25 19:14:44 2023 : Debug: (21) Sent Access-Accept Id 42 from 172.16.16.11:1812 to 172.16.91.104:39266 length 0
radiusd:14899:1690337684.628002:Tue Jul 25 19:14:44 2023: Tue Jul 25 19:14:44 2023 : Debug: (21)   MS-MPPE-Recv-Key = 0x907ed592f67625f2c0e186964e261feddaf475452ed489fbbe0a82e90d672419
radiusd:14899:1690337684.628027:Tue Jul 25 19:14:44 2023: Tue Jul 25 19:14:44 2023 : Debug: (21)   MS-MPPE-Send-Key = 0x6d35e9087ba66cb9d08f086e248dad6966a09b0bd2d7d3606bb73e65c2eb8620
radiusd:14899:1690337684.628061:Tue Jul 25 19:14:44 2023: Tue Jul 25 19:14:44 2023 : Debug: (21)   EAP-Message = 0x03f50004
radiusd:14899:1690337684.628087:Tue Jul 25 19:14:44 2023: Tue Jul 25 19:14:44 2023 : Debug: (21)   Message-Authenticator = 0x00000000000000000000000000000000
radiusd:14899:1690337684.628120:Tue Jul 25 19:14:44 2023: Tue Jul 25 19:14:44 2023 : Debug: (21)   User-Name := "host/butters.ag.home.lab"
radiusd:14899:1690337684.628155:Tue Jul 25 19:14:44 2023: Tue Jul 25 19:14:44 2023 : Debug: (21)   Tunnel-Private-Group-Id += "201"
radiusd:14899:1690337684.628184:Tue Jul 25 19:14:44 2023: Tue Jul 25 19:14:44 2023 : Debug: (21)   Tunnel-Type += VLAN
radiusd:14899:1690337684.628255:Tue Jul 25 19:14:44 2023: Tue Jul 25 19:14:44 2023 : Debug: (21)   Tunnel-Medium-Type += IEEE-802
endpoint should be on vlan 201 according to radius, but ended up on vlan 4 which is default for the ssid.
Is there a tutorial available to connect with SSH?
@Niels Yes: How To Use SSH Keys For Management : Please let me know if you have any questions!
@Alta-Jeff Thanks!
Hi @Niels have you had a chance to look at the logs I provided, anything I should try different?
Hi @aglabs,
I think you need @Alta-Jeff to inspect your logs :wink:
Hi @Alta-Jeff, was the log output I provided what you needed? any feedback on how I can get dynamic VLAN assignments working?
@aglabs From my testing, it works great as long as you set the tunnel type to 13 (VLAN), and the tunnel medium type to 6 (802). Did you try setting the default VLAN to 1? Obviously not a long-term solution but might help narrow down what’s going on.
@Alta-Jeff Thanks for the hints :slight_smile: Did a bit of playing, Found two things:
First: It appears setting default vlan to 1 allows radius dynamic vlan to work with WPA2.
Not saying this is an issue/bug, but definitely not typical for ap/switch to override radius accept with its own settings if they arent default (maybe a documentation opportunity)
Second: Additionally what might be a bug, is when wpa3 is used (default vlan is 1 still), dynamic vlan no longer works.
@aglabs Thanks for digging! Ideally it should use your defined VLAN as a fallback, so we’ll get this working as you had originally expected, and look into WPA3.
@Alta-Jeff Did you get anywhere with WPA3, was just testing WPA-Enterprise with a Ubiquiti Cloud gateway ultra as the radius server and could only get dynamic VLAN working if I disabled WPA3 and set the vlan to 1.
@dragon2611 Can you confirm that it’s working with WPA2 at least? If you can gather logs from the AP during the WPA3 authentication, that would help.
It did as long as the vlan in the ap settings was 1.
When it was wpa2 with vlan 1 set I got put on vlan 15 (which is what I’d set in radius) but if the default vlan on the ap was set to 5 that’s where I got placed regardless of what radius was saying
@dragon2611 Any chance you can capture the RADIUS exchange for WPA3-enterprise, and the AP logs during authentication?
