HomeKit, IoT and AirPrint issues
Hello,
I am discovering the same behaviour. I am unable to connect to my Canon printer using AirPrint after update to 2.0c (AP) with 1.2j (switch).
Any update on this?
Thanks in advance!
Mira
I disabled the Fast Roaming feature in the SSID, as a workaround, and everything is rock solid since then.
With Fast roaming, 2.4G devices are bouncing back and forth between each APs and are not able to stick to the closest one.
Try to disable it and see if it helps you out too.
Yes that helped! Thank you!
M.
i dont have Fast Roaming enabled and i only have 1 ap now. guess i have a different issue from you guys
Hey @Alta-Jeff, any chance that i can help test out any beta firmware that you are working on? fix for multicast issue would help my main problem
@knsai I’ll reach out to you directly.
