Please enable (or at least offer a config option) to set cake (or at least fq_codel) on the interfaces on devices. This is well supported in openwrt. The tests I’ve seen indicate that on fifo buffers are being used.
see Any latency / bufferbloat tests when Alta APs are under heavy load?
When comparing side-by-side with most APs, the Alta is pretty good, but Eero 6+ beats it. Eero’s only really advantage here is cake on the interfaces.
Thanks.
