This update to Alta Control expands visibility and policy management capabilities across the platform, with enhancements to network monitoring, access control, firewall management, and device discovery, alongside a variety of usability and workflow improvements.
WiFi: Add support for schedule profiles.
WiFi: Add support for scheduled filters.
Devices: Add device temperature metric to graphs.
Switches: Show total POE budget in Device Card.
Firewall: Various improvements, including simple port-forward rule creation mode.
Allow 0.0.0.0/1 remote VPN routes to support full-tunnel VPN configurations using paired /1 routes. To route all traffic through the VPN, configure 0.0.0.0/1,128.0.0.0/1.
Audit Log: Improve several log messages.
Improve Alta device discovery.
Correct. We previously disallowed both 0.0.0.0/0 AND 0.0.0.0/1 in the remote subnet validation. 128.0.0.0/1 has always been allowed. We still do not allow 0.0.0.0/0 but we added 0.0.0.0/1.
IF you require true full routing, you would need to enter both, comma-separate, like so: 0.0.0.0/1,128.0.0.0/1
EDIT: Updated the changelog entry, hopefully that should help clarify the behavior. Thanks for raising this!
I assume that supporting 0/0 routes for full tunnels will eventually land (maybe about the same time as policy routes over VPN interfaces), and we’ll get some nice UI features to policy route the tunnel itself via the WAN(s)?
PBR to VPN endpoints is under internal testing, so definitely coming fast. As far as routing everything over a VPN with 0/1,128/1, that can already be done.
