When you change any setting other than “Default” or “Auto” on the network tab, the device gets disconnected and loses its route. To restore normal operation, you have to reset everything back to the default or auto settings.
Here’s an example of an iperf3 test result:
iperf3 -c 10.0.0.1 -P8 -t 600
Link to image
And with the reverse direction:
iperf3 -c 10.0.0.1 -P8 -R -t 600
Link to image
Notice the download speed drops by about 400 Mbit compared to the upload when using the -R flag.
Additionally, I disabled acceleration, DPI engine, and IDS at manage.alta.inc and as follows:
ssdk_sh flow status set 0
ssdk_sh port flowCtrl set 5 disable
ssdk_sh port flowCtrl set 6 disable
However, the speed is still terrible. Initially, when I started a torrent, I was able to reach 1.88 Gbit down (on a 10 Gbit connection), but within a few seconds, the speed dropped drastically to around 100-200 Mbit/s.
I have two ISPs, and I initially suspected the new ISP was throttling me, but when I tested with the old ISP, I got the same issue. My old ISP doesn’t throttle, and even on their 1 Gbit connection, the speed drops to around 10-20 Mbit/s.
When I connected both ISPs to my MikroTik router, I had no issues. Everything worked fine, maxing out the connection. I’ve been testing Route10 for nearly a week, and these ongoing issues are extremely frustrating. I’m seriously considering making a YouTube video where I smash this router to pieces!
Unbelievably a unfinished product and we end users suffering.
