I’m not understanding. The firmware version immediately before 2.4l was 2.4k, so how is there an issue with upgrading from 2.4k when the device is already running 2.4k?
It’s a fix for a corner case bug that prevented AP6Ws on firmware 2.4j and couldn’t upgrade to 2.4k. If your AP6W is already on 2.4k, then you weren’t affected by the corner case bug and this 2.4l update would be benign for you.
