AP - Release Notes
AP7-Pro Firmware 3.0j Released
  • Add support for MLO (Multi-Link Operation)
Join the discussion and share feedback HERE.
AP7-Pro 3.0k and AP6* 2.4k Released
  • Improve mesh loop detection
  • Add support for searching for APs by BSSID in controller (including globally)
  • Add support for disabling individual passwords
  • Add support for OWE (Set WPA3 to On in Open SSID)
  • Improve system stability
AP6W Firmware 2.4l Released!
  • Resolve issues with upgrading from 2.4k
https://forum.alta.inc/t/ap-release-notes/6882#p-27454-h-15f-1
AP7-Pro Firmware 3.0l Released!
  • Improve latency during AP scans
Access Point Firmware 2.4m (AP6*) and 3.0m (AP7-Pro) Released!
  • Add support for captive portal email collection, throttling speed until email is verified
  • Improve connection reliability during AP scans
  • [3.0m only] Add support for Multiple Passwords in WPA3/6 GHz, using DecoyAuth
AP Firmware 2.4n and 3.0n Released!
  • Improve stability on large sites, as well as when there are many VLANs
AP Firmware 2.4o and 3.0o Released!
  • Add support for forcing devices to connect to specific APs and bands
  • Various scalability improvements
  • Resolve some intermittent issues with Hotspots
AP Firmware 3.0p Released!
  • Remove eMudhra and Sectigo/Comodo AAA root certificates
  • Address several Linux potential skb vulnerabilites, including ZDI-CAN-33367
  • Improve reliability on networks with hundreds of VLANs
  • Improve client compatibility when using guest backup network
  • Captive portal: Allow user to optionally view typed password/voucher
  • Revert to original config after fallback-upon-failure is no longer necessary
  • Resolve issue with manual setting of 80 MHz channels
Deployment for this update has been paused for all AP6 devices (including AP6, AP6W, AP6-Pro, and AP6-Pro-Outdoor)
This update is being rolled out now, to AP7-Pro. You can manually initiate the upgrade if you’d like, or it will automatically update overnight (if auto-updates are enabled). The complete, up-to-date change log is available here:
AP Firmware 3.0q Released!
  • Includes the fixes from 3.0p
  • AP6: Resolve intermittent stability issues introduced in 3.0p
  • Improve mesh stability
AP Firmware 3.0r Released!
  • Restore performance to pre-3.0p levels (including 2.4o levels for AP6*)
AP Firmware 3.0t Released!
  • Mitigate CVE-2026-98432
