AP6: same-SSID Wi-Fi clients can’t reach each other with isolation off (firmware 3.x)
Since the update from 2.4 to 3.x (seen on 3.0q, 3.0r and 3.0t), the AP6 sets ap_bridge to 0 on every SSID, even when the network has isolation off. Wireless clients on the same SSID then can’t reach each other, On 2.4 this worked.
Reproduce: create a network with isolation off and an SSID on it, then run cfg80211tool <iface> get_ap_bridge on the AP. It returns 0.
Workaround:cfg80211tool <iface> ap_bridge 1. It is lost on every reboot, firmware update or Wi-Fi reconfig.
Please do not set the ap_bridge option to 1; it will likely cause network loops and other issues. The ap_bridge option is set to 0 by design – we use Linux bridge hairpinning to bridge traffic between clients - not ap_bridge. We will look into your report, though.
I’m unable to reproduce any inter-client communication issues, whether on the same radio, different radios, or different APs. There is likely something specific to your configurations that is causing this new behavior.
@apa and/or @jeffk931 if you can invite me to your sites, and let me know which devices should be able to communicate with each other, but cannot, I can see what’s going on.
Looks like I am having this problem actually. I will DM you, you should still have access to my site when we were looking at the 802.1x identity oddities.
