AP Firmware 2.2x Released!
This update delivers targeted enhancements to system visibility, authentication, and connectivity, strengthening observability, security, and reliability across the platform.
  • Add support for transmitting AP name in beacon, for improved troubleshooting with 3rd party tools (Settings->System->Advanced).
  • Add IP address to RADIUS accounting packets.
  • Improve mesh connection reliability,
  • Add wired driver to wpa_supplicant (CLI support only).
thank you always support.
:heart_eyes:
I have upgraded the AP firmware to version 2.2.x, but the user IP address accounting logs are not working. Please see my screenshot.
With UniFi Access Points, no additional configuration is required, and user IP addresses are automatically displayed on the dashboard. However, this is not working in my current setup.
Can you capture the RADIUS accounting traffic between your AP and the RADIUS server and DM them to me? There should be Framed-IP-Address attributes with the IP address for the client in there.
Dear Sir Alta-Jeff,
I have sent you the Wireshark capture taken between the Access Point (AP) and the RADIUS server for your review.
Please kindly check it and let me know if you need any additional information.
Best regards,
TAYZAR PHYOWAI
