WPA3 Settings For an M1 Air
Hello!
On my wifi network I have PMF = On and WPA3 to On. All the devices connect properly, except my Mac M1 Air. Is there anything else that I need to change? Also how do I setup IPV6, I have a firewalla router and it is setup properly for IPV6 on the Alta Portal under Settings\Networks I have IPV6 enabled, Is there anything additional needed? I dont see the IPV6 on the devices tab.
Did a quick test with my M1 MacBook and didn’t seem to run into an issue. Using those same settings for the SSID. Is there anything popping up in the logs when trying to connect that Mac? Viewing logs from the Alta controller is described here a bit
https://help.alta.inc/hc/en-us/articles/39964980287003-System-Logs-and-Audit-Trail
Yeah, turning IPv6 on in the network settings should be enough if the router is getting an IPv6 address. Unfortunately I don’t believe the Devices tab shows IPv6 right now, but you should be able to see if your Alta AP is getting an IPv6 address by hovering over it’s IP address in the Network tab :slight_smile:
