I think there’s a small bug here. The computer is hard-wired but map shows wireless connection. I do not even have any APs connected!
think thats just the default icon, Uplink.
The dotted line is for wireless, solid line for wired.
Having said that, my uplink/WAN port on the map is currently showing as my Proxmox host. Before that, it was showing as the Unifi Flex Mini switch I’m using. The map shows everything else correctly for me - just not where my modem should be.
@ZamorakWasRight Is the MikroTik there a switch?
@a5a7e2f748a97485aa26 If either of you would like us to take a look, please DM me and I’ll send you an email for an invite to your sites.
i have a somewhat similar issue with the map, it shows everything connected with L1
it shows my wifi router as beign the modem/internet even though thats on W1 when looking at how it is positioned
the LAN of route10 is connected to a TP-Link 16port easy smart switch to which the vast majority of devices are connected.
furthermore there is a TP-Link 8port easy smart switch that connects to the 16port and is used to connect speakers
I have similar issues with the Map. Also, would it not be easier to view if you could rotate it?
