Wifi 7 question
Hi there
Just wondering for the wifi 7 APs would you guys do something similar to the AP6 Pro where it would be a AP7 option available for example if you wanted a slightly budget option or something with 2.5 GigE instead of 10GigE.
I have a 2.5Gig network so wondering when the wifi 7 options would be available
This is a consideration for the future, but currently we are focused on the first WiFi7 SKU that we can deliver.
Thanks and is there a timeline when the wifi 7 APs would be launching
The WiFi7 AP is currently on track to be available in Fall of this year.
I’m still using Asus due to wifi7, dual band 6ghz 320mhz channel width, MLO And 10gbps ports for each AP. When Alta releases AP that follow the above description, I will certainly switch. Now there are m.2 E keys for laptops now that support MLO and I can see the client connected as MLO from the asus router app. If this was the intent for the route10 , then when the APs are released then I’m all ears.
