Are there any WIFI 7 APs going to be released by Alta this year?
Unifi just released Access Point U7 Pro - Ubiquiti Store United States
@Gio We are working on it!
Do you have an estimate timeline for availability?
Most importantly will it match or beat TP-LINK EAP773 specs? Which are basically the same radio specs of Ubiquiti U7-Pro except TP-Link did not cheap out on the network port and uses 10GB instead of 2.5G.
WiFi7 for sure, but 6Ghz 6E/7 spectrum is what I need for outdoor spaces. Iāve been patiently holding out for the outdoor product but I really need this extra spectrum to handle events where we get a few thousand people and need to āspread outā over more spectrum. Currently handling this with more APs on 5Ghz channels but kinda hitting a wall there.
Any News about the timeline? More and more AP from differnt vendors have wifi 7 products. I need some new AP“s and don“t want buy AP“s without 6Ghz.
How is this going? I will have the Route 10 here next week.
Waiting for WiFi 7 AP and some Switches that have more 10GB ports to change my UNIFI WiFi6 setup.
I have high hopes for you guys.
I work at a MSP and we sell a tonne of UniFi gear and I think you guys have what it takes which is why I am willing to change a few $k worth of gear at home to do a full swap.
Me like!
Please make it with 2.5Gbps ethernet this time ![]()
@dennii.inc Thanks for the support and the vote of confidence! Our WiFi7 AP will be out the first half of next year. You will love what we are doing with it!
It would be wonderful if the original AP6 mounting plate still worked, or the new mounting plate used the same outline in terms of screw hole pattern. Having to create additional holes for a new mounting plate pattern stinks.
@Joe You will be happy.
As a follow-up to this, should we assume these will be accompanied by 2.5g PoE++ switches?
I bought my Route10 a month ago, and am holding off upgrading the rest of the network until I can get APs and 2.5g PoE++ switches from you guys.
Love the gear and mission!
@Wboom Thanks for your support and question! Glad you are with us! Yes on your assumption!
Any chance of atleast knowing whether it will be 2x2x2, 2x4x4 or another setup?
Mounting holes, Yes (which is really not a big deal just stick with single gang opening). The way the AP mounts to the wall plate, please change (I stress āplease changeā). You are not winning any awards for smallest access point. Increase the size (to make heat dissipation better and easier to mount; if you can do that in a small footprint great but small is not the goal, performance and easy of install), a 2.5 GBs port, and a pass through port. That is what I am looking for. POE++ is nice to have, especially if that can be passed on to the pass through port (to connect a camera or another AP). But I rather have two separate APs instead of truing to pack to much in to one AP part number and making it to expensive.
