I am looking at getting some of these APs, and possibly switches when they come out. Will there be more places to purchase that doesn’t require you to have an account with a distributor? Will they be available on Amazon/CDW …ect
I am not sure where in the world you are located. I purchased my APs from https://www.ispsupplies.com. I don’t recall having to set up anything special to purchase from them
im in the uk and only linitx is the only place currently able to purchase for a consumer
Thanks for this!
Just to avoid any confusion we can supply all UK customers directly.
Just click the Add to cart button, then Checkout.
Thanks @NickShore !
