Where is DHCP option 60 ? (Vendor Class ID)
I just change my ISP for a 8Gbps connexion and I can finally use the route 10 I received 8 month ago.
Tag vlan OK / clone mac adress to match the ISP Sagem F5696b OK.
I start checking all the option and look through the route 10 config page but i can’t find the DHCP option 60 that is mandatory for nearly all french ISP.
without this my connection drop from 7500/950 Mbps with the ISP box to 60/0.25 Mbps with the route 10.
Am i missing something or the DHCP option 60 is not part of the route 10 ?
I was ready to order a NFR kit for my company but without this option it’s not even an option anymore.
This option is not available in the GUI right now, but support may be able to help you access it through the CLI. I suggest reaching out directly.
https://help.alta.inc/hc/en-us
Thanks for your help I made a ticket.
After watching closely all the thinks I need for my ISP there is something else that may be the cause.
I need to Tag CoS (802.1p) - with priority 6 so the dhcp request come first.
Is it the same thing as putting QoS to 6 in my wan settings ? For me it looks like the whole traffic is going with through priority and not only dhcp request with QoS at 6 but my network knowledge regarding CoS/QoS is very limited.
Hello Nexpyro,
Unfortunately, we do not support Option 60 currently, but it is on the roadmap to being supported hopefully within the next month!
