VLAN problems on SSID
I am using Wifi temperature sensors for quite some time without any issues with an AP6 Pro.
Recently I assigned a different VLAN to that same SSID and since then all of those sensors are unable to connect to that SSID.
Every other device has no trouble connecting to that specific VLAN assigned SSID.
Once I switch back to default VLAN1, the temperature sensors are connecting again.
Without expecting any healing I tried resetting the sensors as well but obviously that didn’t fix the issue.
How is that even possible?
I was always thinking that SSID assigned VLANs are not even visible to the client device? Am I wrong or what could be happening?
Would you mind posting screenshots of your SSID setup, including the advanced section? We might get some insight from seeing the other settings.
Sure, these where the settings when the sensors where unable to connect.
Also tried unchecking Multi-VLAN, don’t know what that really does tho.
I just realize I should try again with network type “Standard” instead of “IOT” in case this could make a difference to some devices in with non default VLAN.
Will try that once possible.
But just for my understanding, clients do not know about any SSID assigned VLANs at all, is that correct?
Those Tuya crap devices are just more crappy than I thought…
They never request new IP address thus no connection in different VLAN.
Not even after factory resetting… (which I feel is not really factory resetting everything aswell)
You need to ensure that your VLANs are configured in your network as well, not only on your SSID.
Clients, by default, don’t know about the VLAN they are in. They can know, if you have a smart enough client, but in 99% cases you will not have a client who tags any VLAN on its own.
To pass VLAN traffic across a switch, tag the ports with the VLAN where it’s allowed to send that data. If no ports are tagged with that VLAN, it doesn’t have any ports to travel through.
Thank you for pointing that out.
All of my other devices work fine with that VLAN assigned SSID, getting coresponding IP/subnet of that specific VLAN, but the Tuya’s - nope.
My conclusion is, this does not seem to be an issue with VLAN at all, since the thermometers just not accept a different IP, not even in the default VLAN when forcing .42 instead of the DHCP assigned .40
They are just stuck on whatever IP they first got.
It IS WEIRD, yes :smiley:
I just won’t use them
