VLAN per device possible?
If VLAN is setup correctly. Is it also possible to add a VLAN per device?
I know about the SSID, but I want to know if it is possible per device also. I see the option if I click on a wifi device.
If you click on the device and assign a vlan it should override the current vlan that it is in.
