Unstable Network - for Gaming. Suggestion required for settings
Hi,
Client is facing frequent error messages while gaming.
Screenshot attached.
No filters added in AP. All firewall settings are default.
Any setting to be done in Firewall?
I game on route10 with a 16 port switch. I have yet to encounter any issues, can he go hardline for testing purposes?
Might a WAN related issue
have you run any diagnostics on teh WAN conection, latency, routing issue?
Ping see if there is any latency or routing issue to the site in question?
I will check that if there is option.
Can that be checked via Alta remotely?
No not on the Route 10 , can you get the Client to do soem basic PINg tests, Speedtest, see if not WAN related issue.
