UI Glitches, rename and sorting
Hi,
I’ve now completed several Alta Labs installations and I’m quite satisfied overall with the product. However, I’ve encountered a couple of annoying UI issues that I’d like to bring to your attention:
1. Access Point Renaming Bug When renaming multiple access points in succession, the interface carries over the previous AP’s name to the next one you’re trying to rename. This results in two access points accidentally having the same name. The current workaround is to refresh the page after each rename before moving on to the next device. Not ideal workflow-wise.
2. Device Sorting Issue Sorting devices by link doesn’t work properly.
Tim
Is this on Web, iOS, or Android? Can you provide videos on how to reproduce these issues, and be more specific in what you are trying to sort by?
