UI BUG >DEVICES - IP ADDRESS - Sort not working
DEVICES: IP ADDRESS SORT does not work.
Hmm, tested, I can’t replicate this on the cloud. It takes a few seconds after each change, but it appears to be correct. It’s sorting my various subnets correctly, as well as the IPs within the subnet. I’ll get some devices populated on a local instance, and I’ll test there, too.
Which browser are you using? I’m testing with Brave. Does it also happen if you try refreshing without using cache, or private/incognito mode (whichever is easier)?
I’ll follow up after I get around to testing on a local instance.
hello @Alta-MikeD ,
Brave MacOS: Version 1.71.123 Chromium: 130.0.6723.116
Approx 38 devices 15 or so static assigned IP, other devices have a MAC/IP assigjnment on the Route 10.
I have tested with Safari (Version 18.0.1 (20619.1.26.31.7), Firefox ESR (128.4.). —- same behaviour - IP address sort does not work.
Also checked the change per 10,25,50,100 - makes no differnce
Also the SIGNAL sort not working
IP sorting does not work. other field sorting is buggy is my experience
This has been resolved on the cloud controller, and a fix for local controllers will go out soon, as well.
