So, inspired by and based on @anon77415413’s scripts for link light scheduling for switches and Route10, and while waiting for a UI-driven scheduling, I’m unveiling a script for switching the Blue/White top-LED on and off and control color and brightness for APs.
A prerequisite might be that the LED-light is set to White in the UI, to release the system’s continuous control over the Blue channel channels. I already had it on White and haven’t checked if Blue would prevent this script. If so, there might possibly be a way to get around that too, but I haven’t dug into that to any extent.
It injects brightness levels for the different Blue and White channels (e.g., /sys/class/leds/white/brightness).
It works, at least, on AP6 Pro.
Set COLOR_CHOICE to integer 0-6 according to preferred colour and brightness (or off altogether, via 0, which doesn’t make much sense of course…)
#!/bin/sh
# AP LED scheduler with colour presets
# Set COLOR_CHOICE to a number (0–6) to pick the colour for ON
time.
COLOR_CHOICE=2 # 0=Off 1=Blue 2=White 3=Both 4=Dim-blue 5=Dim
-blue+white 6=Dim-white
# --- Map number to blue/white values ---
set_color_values() {
case "$COLOR_CHOICE" in
0) # Off
LED_BLUE_ON=0; LED_WHITE_ON=0 ;;
1) # Blue only
LED_BLUE_ON=255; LED_WHITE_ON=0 ;;
2) # White only
LED_BLUE_ON=0; LED_WHITE_ON=255 ;;
3) # Both (pale blue)
LED_BLUE_ON=255; LED_WHITE_ON=64 ;;
4) # Dim blue
LED_BLUE_ON=64; LED_WHITE_ON=0 ;;
5) # Dim blue + white
LED_BLUE_ON=64; LED_WHITE_ON=32 ;;
6) # Dim white
LED_BLUE_ON=0; LED_WHITE_ON=64 ;;
*) echo "Unknown color choice $COLOR_CHOICE, defaulting to
off"
esac
turn_on_lights() {
echo "Turning AP LED ON (colour $COLOR_CHOICE) at $(date)"
# ensure manual control
echo none > /sys/class/leds/blue/trigger
echo none > /sys/class/leds/white/trigger
# set brightness values
set_color_values
echo "$LED_BLUE_ON" > /sys/class/leds/blue/brightness
echo "$LED_WHITE_ON" > /sys/class/leds/white/brightness
turn_off_lights() {
echo "Turning AP LED OFF at $(date)"
echo 0 > /sys/class/leds/blue/brightness
echo 0 > /sys/class/leds/white/brightness
LAST_ACTION=""
while true; do
TIME=$(date +%H%M)
# turn ON at 06:30
if [ "$TIME" = "0630" ] && [ "$LAST_ACTION" != "ON_0630" ];
then
turn_on_lights
LAST_ACTION="ON_0630"
# turn OFF at 19:30
elif [ "$TIME" = "1930" ] && [ "$LAST_ACTION" != "OFF_1930"
]; then
turn_off_lights
LAST_ACTION="OFF_1930"
elif [ "$TIME" != "0630" ] && [ "$TIME" != "1930" ]; then
LAST_ACTION=""
fi
sleep 30
