Turning Off POE Power on Switch Port
Hi ,
I am using a 8 port POE Alta Switch. Need to check if we can turn off power of a single port as its connected to the router and its creating a issue on regular basis.
You sure can, simply click the port then scroll down to the PoE Section :slight_smile:
No there. :flushed:
Ah port 1-4 only has PoE :slight_smile:
