Trouble with 'Allowed VLANs' setting
Hello,
today I received my Route10 and I’m having trouble setting up vlans.
It should be easy, but I don’t know what I’m doing wrong.
The Route10 is connected to a USW-Aggregation as well as a UDM-SE. There’s vlan1000 set up on a UDM-SE, which is tagged on the uplink connection to the USW. The USW has the same configuration on all Ports, untagged vlan1, all tagged vlans allowed.
At the Route10 I configured the white color group, allowing only untagged vlan 1 while blocking all tagged vlans. It doesn’t work, I can still ping the vlan1000 IP-Address of the Route10 from the UDM-SE.
Restarted the Route10 several times, no luck.
I also double checked, it’s the Route10 that answers the icmp requests, they stop immediately when I unplug the uplink cable to the USW.
I am hoping the team can reach out to you to help, but one thing to keep an eye out for is color assignments are NOT working on Route10 right now. You will need to leave all colors black, and manually configure the VLANs.
oh wow… thanks for the info. I’ll configure it manually per port then and check if this solves my issue.
