Temp in Celsius
Please add the ability to have all measurements in metric such as temp in Celsius
Temps should be available in Celsius already. Click the temp and it should toggle between F and C.
Sorry for clarity I meant the ability to set the default. Whenever I go into a device it shows in f and need to click to get c. Under my profile it would be great to set to always show in c
Ah, ok. Yes, that’s true. As I only have a few network devices (3xS8, 1xR10 and 2xAP6P), it’s not much of a problem to click once per device, but for larger installations I’m sure it would be beneficial to have a system wide configuration to set it as default.
Not sure how the devices decided on which is the default, but I found mine already always in Celcius whenever I click, I don’t have to toggle it.
