I can’t connect to my tailscale network from my server since the new firmware .. if there any go around for this. My tailscale shows my devices available but I can’t connect browse the network
We don’t have any known issues that would account for your Tailscale issues or similar reports. While anecdotal, my Tailnet is working fine.
If you are still not having any luck, please reach out to support. We’d be more than happy to take a look.
Hi, I’ve had a similar problem since the 1.4x update. I’ve had issues with something called NAT Punch since then. I didn’t have this problem before the update, and I thought the new 1.4y version would fix it, but it hasn’t. I don’t know if it was just a coincidence that this happened to me on the same day as the 1.4x update, but I’m mentioning it in case it helps with the investigation. Thanks.
I’ll have to call after work when I get home. I tried reinstalling tailscale. .. I check my admin panel and I see it’s connected. But it won’t respond if I’m not on same network. I thought maybe a tailscale relay issue. But it’s been a problem since update
Thank you for the report.
@skani and @PotaRunner Please do reach out to support when you have a chance (phone/email/chat), and we would be happy to dig into this.
Has anyone found a fix for this yet ? Sent capture
Landed up being a issue with my server .. some reason it deleted my subnet from server and couldn’t run dns fixed the ip and now no problem thanks Anthony L for the help
