System alerts at zero on the WebUI
Hi All.
Across all my sites the Alert bell icon always shows as Zero. although i do receive email notification for disconnects. If I change the search parameters to 1 month and there are zero results? Do I need to enable something? I am full admin on all sites
Regards
Jay
HI @Jay_Spengeman. At this time the Alert bell icon is not implemented in any way. I am sure it will change in the future, but it is not just you. It is not in use yet.
Hmm, unless it changed, you used to be able to see the access request notifications there. Like if you’re using scheduling on an SSID and have Users can request access during down-time enabled, you’ll get an email notification but unanswered requests used to render there, too. Pretty sure that’s the only one currently.
Sorry for the oversight there @Alta-MikeD. I have not used or tested that feature, so I haven’t gotten that alert.
No worries at all, you’re good!
