When will this be available for general release?
Is it dependent on any internet connectivity to function (i.e., if ISP connection is down, can you still properly control/configure wireless)? Internet needed for initial configuration?
Backups - how will this be available? Able to export configuration?
Migration - will there be option for migration from existing cloud controller?
Should be available within the next month. Yes, as long as you can connect to the controller, you can configure your devices even if the Internet is down. You will be able to backup and restore the controller, similar to how it can be done in the self-hosted version. We will add support for migration from cloud at some point, but it will not be in the initial release.
