Added my public key and used the other key file to login but it still asks for a PW. I can SSH my APs with the key though.
When you added it did you tick Administrator?
There’s no box for that when adding the key.
Is it up to date?
Local controller or software (like docker)?
Local and no I had to factory reset it and I can’t update it that’s why I need to SSH so I can do the fix to check for updates again.
Alright finally after a full reset of my network I got it reset updated and the SSH admin option showed up.
