i was trying to figure what the commands are or is their a list of commands to use for this as there no help or ? command
pr any help text for commands to use
There isn’t an official list of SSH commands, and mostly used for debugging purposes in case you’re having issues. We probably won’t publish any kind of documentation for it, as it might change and we’ve intended on the UI be the primary way to manage the devices.
If you have specific questions on how to do certain things we can always suggest them though…
