Site to site IPSEC
is there any tutorial how to setup site to site IPSEC?
atla route 10 to alta route 10 not able to connect ( using draytek to darytek works )
alta route 10 to draytek doesn’t work
Have you read the below?
https://help.alta.inc/hc/en-us/articles/32642651503643-Configuring-IKEv2-Remote-User-VPN-on-Route10
there is no site to site configuration.
Could perhaps a VPN-server on one site and a VPN-client on another site be considered a site to site setup? So, the documentation @mentalinc referred to might still be the one?
No. its a server - client not a tunnel site to site
Ah, sorry. I was of the impression that a server was needed at one location and a client at some other location to create a tunnel from one site to another.
Hot off the press: https://www.youtube.com/watch?v=gN0d9rpcTjM Please let me know if you have any further questions!
can I use a static IP (public) as the hostname or I have to use the dynamic dns address created by alta?
Thanks, Jeff! Any chance we could get this written up as a help article as well when someone has time? Even if it’s initially just an article with a link to this video, I imagine that would be helpful for anyone searching in the future.
You can use either static IP or hostname. That’s just the address that the VPN client will initially try to connect to, and then use remote/local IDs, etc to authenticate.
We have been working on that, and should be able to publish it soon.
the video tutorial is great / it works
the missing part was pinging from and to the router
thank you
