SFP > RJ45 Adapter Dropping Packets
Hi all, I’ve recently purchased quite a cheap SFP to RJ45 Adapter from Amazon, its did however have some very good reviews and hardly any negative ones especially around performance. I’ve noticed although it works, it does drop packets which causes VPN issues when WFH.
Is anyone aware of tests that I could run that would eliminate the Adapter over the port, I think I can only use the one SFP port as LAN too, although as I type this I’m going off to check that as well..
and suggestions welcome as I don’t want to spend out on a new adapter only to find the issues was with the route 10, although I doubt it will be.
Nick
As I thought you can use the other port, and that seems to work with no packet drops on a simple ping test, I’ll leave it in for a few hours and see if it continues to behave.
It is possible to reconfigure both SFP ports for either LAN or WAN (in any combo).
At what data rate are you connected to your modem (assuming the SFP → RJ45 is for WAN)? The reason for asking is that higher data rate connections can be much more sensitive to cable/connection issues.
Hi James, its this Amazon.co.uk which says Data Rate: 1.25gb/s data transfer rate.
It does seem to be behaving itself on port 2
OK - Cable/connection could still be a concern, but less of an issue than, say, a 2.5+Gbit connection.
I’d recommend monitoring things for now, and if you start seeing issues, perhaps try a non-SFP port (if feasible) as a test.
If you keep noticing VPN drops or issues with ping, please do not hesitate to reach out to support directly, and we can take a closer look.
Yeah, probably should’ve mentioned that its fine on the non SFP ports, I was using these until lately but some new devices have meant I needed to use the SPF port (yes I should’ve bought a bigger switch :slight_smile: ). I’ll monitor and report back in a couple of days, Its a work VPN so is quite noticeable when Teams etc keeps dropping
I did some further testing using IPERF and of course using both SFP ports and running 60 second tests it didn’t have any issues at all, I then just left a ping running for 30 minutes again once on each of the SFP ports and gain no issues. Will see what happens in a real world test as my wife is WFH tomorrow and will be using it for Teams etc
