Setting up Outdoor AP as a Bridge
If I were to use 2 of the Outdoor AP’s one on the house and the other on a boat dock could the dock AP be setup as a bridge while the house is broadcasting for the outdoor area?
We usually add a POE camera on the boat dock when doing a customers lake house. Trying to eliminate the need for a separate PTP piece.
Mesh is fully operational by default, but this is not advised as a permanent or long-term solution. Bodies of water are also problematic for signal stability.
