If you need management access while the internet is down, you can use a local controller, either a Alta-branded Control hardware, or a docker/lxd controller.
So when I make misconfiguration, for example setting wrong IP, PPPoe credentials or wrong WAN VLAN and internet is gone. There is no way to fix this besides a factory reset of the router.
