Separate levels for logging and email alerts in IDS/IPS
Currently the IPS/IDS alert and notification level is configured by the same setting. Logging to the Events list follows the configuration setting. The check box turns on or off alerts, for events at the same level, to be sent to the assigned email.
A suggestion is to separate them so as to be able to set, for example, Medium level for logging in the Events list and email at High level.
