POST /fe/oops
SyntaxError: Unexpected token u in JSON at paccess.js:2:1947399
N.parse ()
at /usr/share/access/be/access.js:2:1959910
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async /usr/share/access/be/access.js:2:1947417
at async y.pgPool (/usr/share/access/be/access.js:2:2017501)
at async t.handler (/usr/share/access/be/access.js:2:1947399)
I had the same problem when I set up my local controller. It’s the “+” in your email. I use the same function in my gmail and it throws off the Alta activation user. If you just register with bobs@icloud.com instead, it will work.
