I might be missing something, but is there any way to view which password a device is using? Ideally in device view so that I can sort by PSK password or password note? I can set up a VLAN per password, but would rather not do that. Thanks!
Under devices there is a Type field which displays which type of ssid its connected to. Like IOT, internet, standard, etc. I don’t know if it differentiates if you are using more than one of the same type though.
Yeah I worked that out, I have some the same type, only difference is bandwidth allocation.
I haven’t seen a way myself, so I suppose a feature request might be in order. Definitely feels like something that would be pretty handy as an additional column in the Devices view. I’d imagine the password note field would be easiest to impliment there ![]()
Yep this would be amazing! I will submit the request.
