Schedules not showing on Wifi Config
Route 10 v 1.5c, Schedules drop down not appearing under advanced config for Wifi. No apparent way to apply schedules to SSIDs
It depends on what kind of SSID it is. If it’s password-based, then the schedule setting would be per-password. If it’s Open/Enterprise, then it would be in the Advanced Settings.
Password-based, schedule not showing anywhere:
I am having the same issue after the update. I have a schedule that locks the kids out at night. My son is not able to request more time and nothing showing under the wifi settings. I have 5 wifi networks.
@2bleere Click where it says “standard” next to your PSK, schedules will be there because they can be configured on a per PSK level.
