S8-PoE Static IP not sticking
Setting a static ip is not sticking after a reboot.
I keep setting to 10.12.10.3 and it reverts to DHCP 10.12.10.53
Hello!
The reason your static IP configuration may not be sticking is that Fallback upon failure is enabled.
This feature monitors the network connection and automatically triggers a failover if it detects that the uplink is unavailable. When this happens, it will revert back to a DHCP configuration.
Are you experiencing any network connectivity issues on the switch?
To prevent it from reverting back to DHCP, you will just need to disable that feature.
Didn’t mess with settings but it’s now sticking. Thank you!
