With 1.2e IP Monitoring is now per switch port. Great for most connected devices… although…
I have a Tado Bridge (10Mbps/Half Duplex) that now has intermittent connectivity issues.
How do I disable IP Monitoring for specific switch ports?
Just leave the “IP Monitoring” field blank for that port … unless I’m misunderstanding your question.
The interface does not allow me to leave it empty.
I have to fill in an IP address or switch it back to autodetect and then it fills the IP address in again.
Deleting the IP on 1.2e works for me to disable it. The IP will probably still show up as the “auto fill” population which you complete by pressing the “>>” button, but the IP is grey meaning it’s not applied to the field.
Applied/enabled:
Not applied/not enabled:
Thanks! I’ll check that… I guess by default it was turned on.
