S2S IP sec VPN connection - Is there a way to check the connection?
I am trying to setup a S2S IP sec VPN connection. Other than in the Route10 VPN tab (where you change settings), is there anyway to see if it is connecting? or if there is any errors?
Probably have to go into the terminal on the router to get some more information. This post from @Alta-MikeD should have a good list a commands to start with :smiley:
Thanks . This was really helpful. I managed to get all the info I needed to find the fault.
You’re welcome! Glad that helped out.
@Alta-MikeD, do you think it would be possible to add those commands to one of the VPN help articles? It would probably be handy as a quick reference for people needing to troubleshoot in the future :slight_smile:
Yes, and that’s done. Looks like below:
Awesome, thanks, Mike!
