S12 10g SFP+ switch
Hi. I finally have all my alta network gear running and I have it secured almost the way I like it , but I’ll fix that. Anyway, I wanted to add a switch to my setup and I saw this https://www.amazon.com/Alta-Labs-S12-Distribution-Management/dp/B0FW6KPY93/ref=sr_1_1?crid=1IOH60E9FCMW0&dib=eyJ2IjoiMSJ9.fawn1FIEgrDp69icZRE5xX6SiyWf9Puc2_yFWvZ_AjI.ZBiNv_b7RF078m_3n9fLZ94yLfZXQVi0I_7VIocXqTI&dib_tag=se&keywords=alta+labs+s12&qid=1764967210&s=electronics&sprefix=alta+labs+s%2Celectronics%2C644&sr=1-1. But Amazon says the delivery is a month+ from now
Has this item not been released yet?
Also I wanted to ask if you can use copper sfp+ with this item. I seemed to have luck with intel sfp+ on the route10
Let us know the 411
Hey TopG,
Yeah, believe the item was released around 2 month ago now in the US. As for delivery, I can only assume they don’t currently have stock at their HQ and are expecting to receieve it around those dates.
You can definitely use copper sfp+ modules with this, don’t think brand matters too much as I am using some of aliexpresses finest cheap stuff (Xicom) and they run smooth across all devices.
