Router 10 compatibility with Italian FTTH provider
Hello,
I discovered the Router 10 through a search on Amazon.com and I am interested in purchasing it.
I currently have a 10 Gbps FTTH fiber connection and I would like to use this router with an Italian service provider, but I am not sure whether it is compatible.
At the moment, my router configuration is as follows:
Protocol: PPPoE
  • VLAN ID: 835
  • PPPoE Username: phone number
  • PPPoE Password: personal password
Could you please confirm whether the Router 10 is compatible with this configuration and can be used with Italian providers?
Thank you in advance for your support.
Hey Vincenzo,
I am in Barcelona, Spain. I am using a R10 with my provider DIGI with the same identification they provided to you: Username + password + VLANID. Its working with 0 issues so far!
It was extremely simple to setup using the KB: https://help.alta.inc/hc/en-us/articles/33805681985435-Route10-Initial-Setup#:~:text=The%20easiest%20way%20to%20get,the%20setup%20wizard%20at%20setup.
Hope it helps!
Hello,
thank you for your reply. I assume that someone else had the same configuration as mine; after all, Spain and Italy are very similar in terms of network configuration.
Now I just need to find where I can purchase the router at a reasonable price.
Hey Vincenzo, we saw your email to sales@alta.inc - We will reply to you asap.
Thanks
Ok thanks
